the second one i linked is not good enough either. try the first one |
So what did you buy for $.01? |
Ok, I will look at some lipos with a higher c rating such as the ones you linked. -Brett |
FYI, when you apply the code on the site, the coupon code actually states: "SAVE $60 on $299.90 ORDER"
So, you really didn't need to add anything to your order. |
When I try to make an order it says:
# Ad number promotion (--------) will be applied when shippable item(s) reach the required dollar amount of $-----. # Shipping charge will be added to your order when the first back-ordered item is shipped In-Stock Items: $.00 Priority Mail International: $.00 Subtotal (based on in-stock items only): $.00 Total Current Charges: $.00 Did you made your order like this? I'm not sure I'm able to order as is, or if the coupon will be applied if not in stock |
If you have the coupon code in your cart when you place the order the coupon will be applied once the item comes in stock and is shipped to you.
He is right. Once the out of stock items come into stock, the coupon will come into effect. I went through the same thing and I called and their support clarified it for me.
-Brett |
- When the backorder combo will be released I will have to pay shippment another time? and - the coupon of 75$ will be applied?(because the item that make the total over 300$ is already shipped) i'll have to write them |
Yes, the coupon will applied when the combo is shipped out. Now for my question: since you guys dont think that the SPC's 8000 2s2p (96amps) will be enough, I guess THESE will be good then. That would be like having 7400mah and 148 amps when put into parallel, correct? One more thing. How is hobby city's customer support? Are they great to deal with? -Brett |
IMO, a pair of Neu 25C 2S 4900's in series would be nicer. You can find them here: http://www.neumotors.com/2008/store/page6/page6.html
That looks good and all, I was just thinking about getting a longer runtime. How long do you think I could bash with those?
Those are enerland cells aren't they? THIS would be even better if they cam back into stock. -Brett |
I am running the spc cells in my mmm 7xl combo geared for 42mph. They dont run hot at all and they handle the peak currents just fine. What type of speeds are you looking for? The MMM neu motor should be even more efficient then my setup. I use a wattmeter to make sure batts are handling load and up to this point I have about 10 runs of this setup.
15-20 minutes probably. IMO, I'd prefer better cells than having added weight and only a few more minutes of bash time for a pair of packs.
| All times are GMT -4. The time now is 11:46 AM. |
