pb4ugo
04.16.2007, 06:20 PM
Originally Posted by Serum
the CEN as published on rc-independent daf?
i guess so?
Don't expect too big of a difference between a 1950 and a 2230.
don't know if you knew; the 1950 has got a 19mm diameter rotor, which is 50mm long and the 2230 uses a 22mm diameter rotor which is 30mm long.
i doubt if you would notice a difference between a 1940 and a 1950 to be honest. Both are capable of more than enough torque, and both are capable of producing the same power (battery limitations)
That's what I was hoping for. I love my 1950, but a project I'm working on would benefit from the shorter length of the 2230.
I'm also worried the 1940 would struggle with 14-15 lbs of truck to haul.
