04.16.2007, 10:14 PM
Well, the battery tray obviously. :) Then, maybe the ESC mount, but I think it can be mounted directly to the CD top plate - or make a simple flat piece of metal and put both the rx and ESC on it like I did. If you don't want to wait for the motor mount, you could use the 46T spur with a little chassis modifications, or use a hardened steel pinion with the stock spur with no chassis mods. No matter what, there'll be some kind of modification to do...
Are you looking for a 4WD vehicle that is sturdy, reliable, and needs no mods whatsoever; just drop cells in and the MM and go? If so, I don't know of anything like that...
