Cajun
04.18.2007, 02:08 PM
Ok, so I've been giving the mechanical braking verses ESC braking and I had this thought. I'f I remove the mechanical braking servo and the brake disk, then use a ESC that has a forward and brake setting with no reverse can't I still use the two speed tranny? Where I run into trouble with the one way bearing is with reverse, right?
