Dafni
Dafni's Avatar
04.19.2007, 11:20 AM
Originally Posted by crazyjr
I got the one with the picco red dot motor, major disappointment, the carb leaks where the metal insert with the highend needle mounts. I got an OS.12 TR i'm going to put in it, should be close to the same power.
I heard when you seal the carb, you should be fine and the engine is apparently not bad at all.
