HummerMan
HummerMan's Avatar
04.20.2007, 09:50 PM
Originally Posted by AAngel
Did you run the truck until it just wouldn't go any more, or did you run it until the LVC reduced the power to the motor? If you ran it until the battery just didn't have enough juice to move the truck anymore, you may have overdischarged the battery. If the battery is overdischarged and you try to charge it, the low voltage will confuse some chargers and freak them out. If you have a dmm or voltage meter, check the voltage of the pack.
I've seen this issue with a couple of chargers where a battery that is under voltage confuses the charger. In this case, and under voltage battery will have voltage too low to be read as a 2S pack, but the voltage is too high for it to be a 1S pack. The charger can't decide what to do and freaks out, then gives its default error, which is a polarity error.
I don't know if the 989 will act this way. It's just what I've seen a couple of times.
Try doing a passive balance on the pack first. Then see if you can get the charger to charge without the balancer in line.
And I'm going to assume thats a very bad thing.... I had the MM set up to shut the truck off at 6 volts. 3 per battery, right? The truck died quick. It would accerate then nothing. I couldn't give it more throttle or anything. The truck wouldn't react. Then in a few seconds later I could give more throttle. But then it would stop....
Brian, I've tried charging it with and without the balancer, with the light solid and flashing... Nothing
www.MRPaintin.com
www.RCCNA.com
RC Club of North America
  Send a message via Yahoo to HummerMan Send a message via AIM to HummerMan Send a message via MSN to HummerMan
