04.22.2007, 12:12 AM
Well, the Jato is 1/10th scale, which is what the MM is designed for, and everything runs cool. Don't know why, but it does. I'm lucky if the temps get to 140*F on a really hot day after two battery packs (~90 minutes) and doing constant high speed runs or track use.
Since the CRT.5 is 1/12 scale, it should be fine, especially since I chose the lowest KV motor in the MM series. Plus, I'm running only 2s.
I can see having issues trying to run the 7700 motor on 3s geared high, but I'm not. Gearing is a little high, but not too bad IMO.
