04.23.2007, 01:02 AM
OK, you have a + and - going to each motor. Put the - ESC wire to the + motor terminal, and the + ESC wire to the - motor terminal. Do the same on both motors or you'll have problems.
EPA=End point adjustment. Depending on the radio you have, you can set how far the servos move at full throttle/steering. Consider your throttle "servo" your ESC. Just make sure both F and R are at 100%. If you're using a stock Traxxas radio, you don't have this feature. If you are using the Traxxas radio, what do you have your 70/30 / 50/50 switch set to?
