neweuser
neweuser's Avatar
04.24.2007, 09:00 AM
Cajun, yes, you are going to need a ubec OR an RX pack. To disable the BEC in the MM just pull the little tab on the connector upward that goes into the RX and remove the red wire. I pulled mine and heat shrinked it back so if I ever need it (not likely) I can. Pretty simple.
