04.24.2007, 02:54 PM
You have to disable the ESC's BEC by removing the red wire from the throttle cable. Since your UBEC is 6v and the ESC BEC is 5v, the UBEC is powering the ESC to some degree. The Mamba Max does the same thing. Just remove the red wire and you'll be golden.
