BlackedOutREVO
04.29.2007, 06:51 PM
Originally Posted by BP-Revo
Just remember that CF dust is HORRIBLE for you. If you can, try to cut or grind with it in a shallow bowl of water, or with a little bit of water running over it to rinse it off.
This is probably only a good idea if you are using a compressor powered tool...since electricity wouldn't mix well with water (ie, no dremel).
thats not a good idea, cf under water makes the cf fray more easily in my experience
