celticclown
04.30.2007, 11:36 PM
for those of you with ESC's taken apart. Has anyone considered stacking FET's to get more power and reliability out of thier esc. You would obviusly need a new case or at least modify the original to fit. A full set of double stacks should make things work much better. I had to do this on my mini-z. went from 2 FET's to 8. My punch went through the roof and it can now handle significantly heavier loads (bigger motor) and more voltage.
