jhautz
jhautz's Avatar
05.01.2007, 10:56 AM
Originally Posted by Serum
4. what is the difference between a high dollar setup (125b and a 1515) and a low budget setup (cc esc and a 8xl) the 8XL will be less efficient on partial load, and will get hotter because of that. the 1515 has got more torque as well. the quark is the smoothest esc available, but the MM is close. I don't recommend the use of 6S on both controllers though.
I don't see a problem with using 6s A123 on the Quark. It would actually be perfect for the Quark. Quark only has problems with 6s lipo at full peak charge. Once the voltage drops a little from peak, it works great. The A123 6s pack will peak at a lower voltage than the 6s lipo so it should work perfectly.
I do agree that 6s A123 will be too much for the MM.
to make it...
or break it...
Silent...But Deadly
