05.02.2007, 12:23 AM
I am having similar good luck with the 16T hardened pinion on my Hyper 8 ( as you know Mike), even after 6 or 7 packs' worth of running. And some of my landings are... well, let's just say "less than pretty" (don't laugh glassdoctor!) so if there was going to be a mesh problem, it would've shown up. You DO NEED lock-tite on the grub screw when running steel on steel!
Mike: I'm sure an LMT 1940/1950 would work great on the MM - too bad you don't have any in stock. ;)
