Compro 16016 programming
AAngel
Compro 16016 programming - 05.03.2007, 01:49 AM
Hey guys,
I got a Compro about a month ago and have had a heck of a time programming it. I'm running a Feigao 8XL and using a Spektrum DX2.0 radio.
I really don't think that I've been doing anything wrong, as I'm getting all of the beeps as I should and the esc is shutting itself off at the end of the programming sequence, as it should. I also did the autoprogram run. I think the esc is defective, so I contacted MGM about returning it. We exchanged about half a dozen emails that consisted of their asking questions and my answering them. Things seemed like they were moving along for a couple of days. I couldn't blame them for wanting to run through everything before having me send it in; but it got to a point where I confirmed that I could indeed enter the programming mode and that the esc was responding with the correct beeps. They told me that there is nothing wrong with the software and stated that it's the software that they are running in thousands of controllers without incident. Since then, I'm not getting anymore responses.
To keep it in perspective, this was all pretty fast. All in a matter of a couple of days, but all of a sudden, no communication. Anyway, I'm afraid that I may be stuck with a pretty costly paper weight.
If there is anyone out there that has a Compro and would be so inclined to do so, I'd appreciate it if you could post the sequence that you go through to program the esc, and please include everything. I'm really hoping that I was doing something wrong.
The problems I'm having are that I can't turn freewheeling on and the LVC doesn't seem to work. I had it programmed for 5S lipo and to cut power to the motor when the voltage gets too low. The last time I ran it, I was trying to program it, over and over again and did so until it quit running. I pulled the batt off and put it on the charger and my charger gave me a low voltage warning and went into repair mode and showed a battery voltage of 14v.
I'd appreciate it if someone could post this programming sequence in English.
Thanks.
