05.03.2007, 03:29 PM
3mm diameter, but the length depends on how thick them mount is, and whether you use the RCM heatsink/clamp (it adds ~1.5mm thickness). I usually turn the screw very gently into the unmounted motor and when it touches a coil, back off 3 or 4 turns. That'll tell you how deep to go.
