05.03.2007, 04:38 PM
Is a flat spot enough? I've had my shaft's dimpled so the set screw goes into the shaft a little bit...Gotta be real careful to give the right depth before it gets drilled...I would like to use a flat spot but I heard it's not enough with these high power setups.
DM
