sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
05.05.2007, 12:11 PM
HotnCold....forgot to read the part about the opto disable huh.....however.....if you don't want to remove the red wire....you can use the dimension engineering sport ubec..and it uses a throttle pass thru feature and the red wire doens't need to be pulled ( ie turning off internal bec).....that is what ubec im running and it works flawlessly as well
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
  Send a message via MSN to sjcrss
