I have just experienced the same problem.
gbekris
Angry I have just experienced the same problem. - 05.06.2007, 08:47 AM
Was there a quick fix to this or did it have to go over to MGM.
Exactly what you described here, just happened to my 16016!
Guys, I have an 16016 Compro - its only 3 days old.
It programmed ok, gave it a test run on the bench only to find that it shut off after a couple of squirts of the throttle. No smoke or anything out of the ordinary. Though on repowering/reconnecting a pack I get the consistent beeping error message. Problem is that it wont supply a BEC charge so even by passing the BEC and running a separate pack wont reset the controller.
I have tried everything yet cant get the controller to reset and take a program. Its not turning the motor at all.
Any thoughts, or is it dead. If its dead do I send to MGM or Monster RC(reseller) for repair?
Regards
GB
