Originally Posted by Cartwheels
The Quark was running a lot cooler but I don't know if it was from the grearing changes or both. It was at least 90*F that day and the Quark was at 112* after 20 min and usually it is at 130-148*F. You can't really see it in the pics but I have the heat sink and 2 of the 40mm fans underneath the ESC. I wish I had more of a definite answer.
Btw those caps are the 270uf ones.
That looks pretty good with the caps on the Quark there, the ones on the MM, the wires look a little small, IMO. How is your Quark mounted to your heatsink exactly?
Where did you get these caps? What brand are they? low-esr?
