05.11.2007, 09:48 AM
Most people here run an XL size motor, or a 1512/1515 Neu motor, or even an LMT (Lehner) motor - any of the bigger ones. The larger can will help with heat. Since you are using the Mamba Max, I would stick to 2 pole motors like the XLs or the LMT 19xx. The wind (turn count) is determined by the battery voltage you want to use.
