05.13.2007, 12:47 PM
If the thermal pad isn't making good contact, your internals will be much hotter than the external case. Taking it apart is not difficult; just use a small flat-bladed screwdriver and GENTLY pry the metal slab from the case. Then, you can gently pull the slab off the FETs.
