zegato
05.14.2007, 04:49 PM
thank you for your idea. I may have also some small rings... I will see then if they could e used in addition to the "the two ~7 mm things that stick into the bulk" to center an lock the diffs.
I understand you experienced the same kind of issue, right ?
regards
