ssspconcepts
ssspconcepts's Avatar
05.16.2007, 07:37 AM
Originally Posted by jhautz
Mike runs the 1515/1Y on 4s in his Maxx. It runs really nice.
I will be running 5S. By the way...I see an awful lot of traffic in the forums regarding problems associated with the Quark 125. I think I have all my bases covered and should be fine, but would you guys please give me one last sanity check? Also note that my maxx is a heavier truck....
I'll be running:
  • Quark 125 with heat sink and two fans
  • Dimension Engineering Sport BEC
  • Neu 1515 2.5d/F motor
  • Evo 25 5000 mah 5s1p Lipo
  • Lightning Stadium Pro 1/8 scale diff gears
  • 5.5" tires
  • 72T 32P spur gear
  • 16T 32P pinion gear
If my research is correct, everything should run cool as a cucumber.
