AAngel
05.16.2007, 01:21 PM
I did put caps on the MM, but I'm not running a Neu. Glassdoctor (among others I'm sure) is running a Neu on a MM. I don't know if he's done the "cap" mod yet.
In any case, this may or may not be pertinent; but I was told my Frank at Quark, that the Neu motors do really well with the Quark controller. He said that the Neus seem to like the Quarks timing, which I believe he said was a 6 degrees. I wonder if the Neu might run better with the MM, if you ramped up the timing on the controller.
