05.16.2007, 02:30 PM
So you think it is hitting the back end of the cup then when the arms flex? When the CVD's are straight (under acceleration) the bones are a little bit more than half the way into the cup (center of pin).
I do have the pillow balls all the way in, I should let the out a bit I guess. At the time it happened, I had forgot to grease the out drives on the rear diff, so it had seized up, and was almost like a locked spool. I have a hunch that was it.
