ssspconcepts
ssspconcepts's Avatar
05.17.2007, 11:00 PM
Originally Posted by BrianG
Well, the thing that's hurting your speed is the HB diff ratio of 4.3:1. Can you use a smaller spur and/or a larger pinion? That's the only way I can think of to increase your speed other than using larger tires or slightly higher voltage. Even if the spur/pinion ratio seems off, it's really the final drive ratio that matters...
BTW: You can use the export button on that page, which will open a window that will allow you to copy/paste the results into your post.
I thought about that too. Problem is that even with different gearing and larger tires I only gain a few mph.
In my other maxx I have basically the same setup except for the Novak HV Maxx 4.5 and I ran the calculation. It was within 4mph of what my telemetry unit indicates (35-40mph). I have also validated those numbers with a handheld GPS.
