Patrick
Patrick's Avatar
05.19.2007, 03:53 AM
If your using a small spur/pinino combo (like 51/13 for example) the finned can version will hit the transmission (I'm not sure about the smooth can, it's smaller than the finned, but bigger than fiegao's ect). With the strobe 51t spur I THINK 18t is the smallest pinion that will fit without grinding the fins.
Mine will fit with 51/20 (mod1), with about 1mm space left to the transmission and about 1mm of adjustment slot left in the motor mount before I would have to start grinding it, so the 18t MIGHT fit (it would be a very tight fit), but I don't have one to check.
Since you are using the 32p gears I'm not sure what will fit excactly. If your using the 72t spur it will fit (depending on pinion), but like we were talking about in your other thread you'd need a HUGE pinion (like mid 30's-40t) to get decent speed (I don't think the stock motor plate would fit that combo though, even if you moddified it)
So if your using the Pro diffs (truggy/ 4.3:1) and your going to use 32p gears you'll probably need something like 66/32t to get ~35mph. The big pinion should make up for the small spur gear, but I'm not sure if it will fit I don't have pinions that big to check. You may still have to extend the slot.
You might just have to wait till you get it and see if it will fit, or how far of it is, then do some guestamating (yes that's a word :027: ) and trial and error.
How much of the stuff on your list do you have.
If you go with a strobe and ofna 51t, I don't think you could go much bigger than 20t without making the motor plate slot bigger, but that shouldn't be much of a problem.
