Thread: Bigmaxximum
Serum
Serum's Avatar
02.12.2005, 07:09 PM
I heard from a guy in Germany, that he was not able to run his bigmaxx on his BK 30/150 controller. It would simply not run powerfull enough.., nor rotate fast enough, or with terrible hiccups.. He tried to program his and play with the timing, but none of this worked..
The BK's top on a 4-pole is 50.000 rpm. With the bigmaxx on 16 cells, you allmost hit the 44000 rpm.. (i don't know if that 50K rpm is his material limit, his software limit or limited by his own frequency.
I also read and that there is a new type of 9918, which runs on a higher frequency.. (the one you can buy now, will be the new type)
I don’t know or heard about anyone running a esc, other then schulze, on his maximum/bigmaximum..
Personally I’m running my bigmaxximum on a schulze 18.97, and i smoked one 18.97... Now I’m running it with a mechanical brake, to spare the esc from the stress of the braking..
