Maxxman
05.20.2007, 05:19 AM
it doesn't really matter much,
but i may add some as many people around here, including S&T as you mentioned as well as others, say that it is better to add some if you can.
the capaciters in the Quark are 330uf low esr caps aren't they.
Also in some ways having squared corners would be better than rounded as you would have more material, therefore theoretically a larger surface area and machining costs a bit lower.
