Thread: Motor braking.
silentbob343
05.20.2007, 02:22 PM
There is a guy over at rcuniverse under the screen name Novak2 that is pretty good about relaying technical questions to the Novak engineers. He's about the only one I know of off hand.
Originally Posted by Aragon
Yes, they are correct. The main problem I have with the regenerative braking theory in the context of our setups is that not a single controller that I know of makes any provision for setting the exact battery chemistry type and cell count or even warns about the use of lithium based packs if motor braking is used.
If ESCs are performing regenerative braking they need to warn users about how to configure their product correctly to accomodate their battery chemistry under braking conditions. Anything less is a serious danger!
The Quark 33A allows the user to select NiMH/NiCD or Li-Poly, but I believe it is only for purposes of LVC.
