IBJAMMIN
IBJAMMIN's Avatar
05.20.2007, 04:52 PM
You can use the MMesc but the 5700 motor is for 10th scale by the time you add everything to run your going to be around 7-8lb's plus your going to need a larger motor. and you will probably have to run the A123 cells in a 2p configuration 9.9v 4600mah min to get the capacity needed.
