IBJAMMIN
IBJAMMIN's Avatar
05.22.2007, 06:33 PM
The MM runs the Neu's fine it's just getting it to go it is set up for unsloted motors and needs an update to run sloted motors seems to be the problem. When is this update comming? from what Joe ford said not anytime soon I have also been waiting for the update or MMM to come out for about 6mo everyone keeps saying to run the Quark but it seems to have heat issues. After seeing Joe Fords responce the MMM is probably going to be another year before we see anything there so for right now you can eather deal with the cogging and wait for the update or run the Quark125 esc.:( If your running brakes you can also try the CC 85-110HV air controllers with a pixie Tx adapter to fix the signal problems with the brake and neutral.:032:
