IBJAMMIN
IBJAMMIN's Avatar
05.23.2007, 06:00 AM
Well I got the Neu 1506-1Y today and got it mounted up in the CRT.5 hopefully the MM esc is going to work? see how it goes tomarrow keep my fingers crossed:013:
I snaped a shot of the motor and battery mount the blue aluminum diff mount is off my CRT with the buggy diff tubes it's 2 pc's and clamps the diff bearing so I can put the diff in and set the pinion & spur mesh with the motor and diff out of the chassis.:027:
I ordered some titanium turnbuckles from Lundsford they dont have a kit yet so I had to piece together my own here's the part numbers if your interested.:017:
#1009 3x20mm servo link
#1069 3mmx2" steering tie rods
#1072 3mmx2-3/8" rear camber link
#1029 4x23mm front upper arms the stock one is 3.5x24mm but lundsford does not have any 3.5mm turnbuckles so I went with the 4mm and im going to open the holes up a little it should be a little stronger I have already snaped a stock one. :dft012:
ID:	2972   Click image for larger version
ID:	2973   Click image for larger version
