Thread: Crt ?
rchippie
rchippie's Avatar
05.23.2007, 08:43 PM
After talking with mike & brian this is what im going with. The motor is a 9XL
post:
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 62
Pinion Tooth Count: 16
Total Voltage: 14.8
Motor KV: 1853
Tire Diameter (inches): 5.5
Tire Ballooning (inches): 0
Motor Current Draw: 60
Motor coil Ω: 0.0092
Spur/Pinion Ratio: 3.88 : 1
Total Ratio: 12.81731 : 1
Tire Circumference (inches): 17.28 inches (438.88mm)
Total Motor Speed: 26401.54 RPM
Vehicle Speed: 33.7 MPH (54.14km/h)
Effective Speed Rate: 2.28mph/V (3.66kmh/V)
Effective KV Value: 1783.89
REAL MEN RUN BRUSHLESS
