Daniel Murray
Talking 07.09.2005, 10:54 PM
Mike you said you can get Picco? how about OMEGA X3 PICCO .26 ENGINE W/PULL START
The specs. seem good
PICCO .26
- ENGINE SPECIFICATIONS -
CLAIMED HP 2.7
RPM 37,000
CARB TYPE SLIDE
CRANK SG/Threaded
CONSTRUCTION ABC
ENGINE CASE SIZE .21
ENGINE BORE SIZE .26
TYPE REAR EXHAUST
PORTS 7 ports
DISPLACEMENT .26 c.i., 4.27cc
CRANKSHAFT Heavy Duty Crankshaft 14mm
CARBURETOR Composite, 8mm insert, changeable
PLUG TYPE Standard
Could you get this engine and how much?
OR
Hyper .21 8 Port Race
PART #53218
CLAIMED HP 2.7
RPM 38,000
CARB TYPE SLIDE
CRANK SG
CONSTRUCTION ABC
TYPE REAR EXHAUST
KEY FEATURES 14mm inside bearings and larger crankshaft
Thank you ,
Daniel Murray
