zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.25.2007, 12:51 PM
I have plenty of experience with A123 cells, I was probably one of the first persons to have acquired some (release day, developer kits). 1p in a buggy is not enough, the voltage drop will be quite substantial. You will have to keep the amp draw below 70 amps to keep good voltage sustained. They can deliver lot's of power for their mAh rating indeed, but you have to design your pack to take into account voltage drop. You should design your battery pack first, then choose your motor.
I have a 5s2p A123 pack, under 100 amp 'spike' draw, the voltage is roughly 14volts.
Do you know what the expected amp draw will be?
