zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.26.2007, 01:39 PM
Actually, I doesn't look like they 'blew', there is no electrolyte anywhere, is there?
If not, then it might be okay.
If you are able to get the heat spreader off of that, would you be interested in the custom case I had designed? It should never ever thermal with it, or at least that what it looks like. :027:
BTW, what epoxy did you use? Is that your homemade stuff?
