Thread: evx
tyrewq
05.27.2007, 01:32 AM
Originally Posted by BrianG
They are probably saying that to keep people from using a really fast (high kv) motor, which will pull much more current than it is rated for. For the same power, there is MUCH less current with 12 cells than only 7 cells.
when you said "high kv" are you referring only to brushless motor? i'm just using plain dual 540 motors(stock mabuchi motors 27 turns). don't know how to convert turns to kv. is 7 cells on evx ok on this setup?
