zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.28.2007, 12:59 PM
AAngel: Yeah, I know that even switching from a Feigao to a Neu or Lehner will make a huge difference. I too, like to consider that (80 to 90%) as being twice as efficient. But I don't really want a Feigao motor like you said, I want a Neu with a very low Kv, and run as high voltage as I can on my Quark (hopefully that is 6s if better/more caps help) to KEEP the same power as a ~7Xl on 4s. I would prob run 6s/5000mAh.
6s doesn't always mean extreme power... 6s on the 1512/2Y is 30,000rpm, and how much torque does it have? Same as an XL Fiegao? It won't be crazy at all, IMO.
Wallot: Using smaller is better than using one large one because the larger you go the worse the ESR is relative to their capacity rating. Typically. 220, 330uF caps are a good size to use.
