gixxer
gixxer's Avatar
05.28.2007, 07:49 PM
Originally Posted by Chapito
The two screws that are no longer being used for the Batt. box work perfect for the rear diff/motor mount. Also, you may want to consider getting some longer ones for the front diff mount; with the spacer in place there are'nt alot of threads penatrating with the stock screws. I went from 1/2 to 5/8 in. long for the fronts.......................
thanks, I did change the front ones to longer screws cause the regular ones wouldn't hold it very secure. I also changed to 4mm because that is what the hobby shop had.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
