AAngel
05.30.2007, 12:16 PM
If I had to opportunity to run dual packs in series, I think that I would go with two trakpower 4900 packs for a 4S setup running a mild motor for racing. Something around 2000kv on the 4S should be a good amount of power that you can get to the ground.
Of course, the battery choice also depends on how long your races are.
What motor/esc setup do you have?
