MetalMan
MetalMan's Avatar
06.02.2007, 12:26 AM
Originally Posted by AAngel
MetalMan, I was talking about increasing the motor timing on the esc to see if the Neu would cog any less. My cogging is pretty bad at times. Sometimes it doesn't cog at all, but when it does, it really does.
I've had the sink pop off of a couple of my MMs. I suppose it'll do that with the right shock. I just used arctic alumina to put it back on.
Do you feel that the hardwiring helped anything?
My cogging is also quite bad when it cogs, but the reduction in gearing definitely helped. The next time the Hyper 8 runs I'll play around with the timing to see if it has any noticeable effect on cogging (for my motor at least).
Arctic Alumina it is!
I've been hardwiring brushless motors for a while now. It is my belief that hardwiring does help rather substantially, but I no longer have any point of comparison to see the actual difference.
