06.03.2007, 05:17 PM
Originally Posted by GriffinRU
Brian, when I was talking about 6 wires (stand-alone brains and output stage), I was thinking about sensored setup... While with sensoreless system it would be difficult to create reliable system if motor feedback wires would be long. It is possible to buffer them and use line drivers or twisted pairs, but that would be not a clean and simple solution. So I will put brains close to output stage.
Meanwhile, mambamax conversion is in process, updates will follow.
Yeah, I can see wire length of the feedback path being a problem. Probably would have to resort to some type of balanced and/or shielded feedback cable. I figured there would be a way to use one brains board, and then stack power boards under it to get the capacity needed.
