06.03.2007, 11:55 PM
What do you have the battery type set to? I'm not really sure what the "manual" lipo setting really does for start power. I wonder if it would work better if you set it to Lipo high, and then go back in and set it for whatever manual cutoff you want. You'd think the manual setting would override the previous setting, but not sure judging by what the manual says:
Originally Posted by Quark Manual
Once you have selected “Manual” from table 3.2-4 and set the cut-off voltage manually, switching the battery type to an automatic cut-off will not automatically change the cut-off voltage. (For example: If you have selected “Manual” and a cut-off voltage of 2.2V, any attempts to change the battery selection to “Li-Poly Normal” or “Li-Poly High” will maintain the cut-off voltage of 2.2V and thus, the cut-off voltage must be reprogrammed).
A little puzzling to me...
If running on NiMH cells, you get better puch by using the NiMH High setting. Also, what torque setting do you have it set to?
