zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.06.2007, 01:42 AM
Yeah, right. Now I don't know which setup for LVC I should use, because a couple of times with my first Quark it cut out. I had to restart it.
When I connect my batts, they are 18V (A123's), then as soon as I discharge them only a bit, they quickly settle down around nominal charge. But, I am just wondering with the relatively higher voltage drop compared to LiPo's, should I use NiMH mode instead? Does NiMH normal mode deliver as much power as LiPo normal, if anyone knows?
