06.07.2007, 09:36 AM
Originally Posted by no mods
i meant to do that.. haha.. ya.. i think your on to something with the c rating. just got off the phone with a very helpful team member of maxamps. He informed me that i prolly should have gone with a higher mah pack cause most likely running on the ragged edge of my cells "constant" rating, possibly even dabbling in the max load stuff.. anyways..
Yeah, it's the same with anything; if you run it up to its max potential, you will be running into reliability issues. I usually over-engineer the battery just so that I know I will never push the battery too far. There is nothing wrong with running a higher capacity battery other than the extra weight and physical size, but if you are running a battery only up to half it's rating, it will run cooler and more reliably.
