06.07.2007, 10:49 PM
The battery and esc being hot while motor cool usually means it is overgeared for that vehicle. Is it the top speed or the off-the-line power you are unsatisfied with? Just curious because if the top speed is higher than you need, you could gear down.
You might also want to mess with the MM settings through castle link software...
