truck stuck at full throttle
ncalenda
Need for Speed
ncalenda's Avatar
truck stuck at full throttle - 06.08.2007, 12:35 AM
I have the li-saver and I had this happen 2 times now. When the li-saver senses the LIPO's voltages is getting low, all of the sudden the truck will go full speed. I have to run and grab it, take the cover off, and then unplug the batteries.
I have the li-saver soldered to the ESC, and the ESC plugs into the li-saver, then, the li-saver is plugged into CH2.
What is causing this?
When I charge the lipos, or use c-cells, it works fine.
  Send a message via AIM to ncalenda
