06.08.2007, 02:46 PM
I figured out my own problem. I put the gear that is attached to the slipper shaft upside down. This was causing the shaft to stick further out and not sit inside the bearing on the other side. The gear had to be hammer down on the shaft for it to work. Hope this helps someone in the furture.
NC
